Znači onda da batalim nov karburator...
Gde god sam čitao o tom Brosol-u svugde ga pljuju, a Solex nisam našao čak ni na ebay-u.
Onda opet skidam ovaj koji imam, uradim mašinsku obradu i ponovo ga kalibrišem, al ne volim ovakav posao...
Kad već govorimo o kalibrisanju i diznama, evo šta sam juče našao (možda još nekom zatreba):
Stock Solex Jets
28 PCI... with removable Venture... Venturi =21.5 mm... Main Jet = 117.5/122.5... Air correction jet
=180/200...Pilot jet = g50... Idle air jet drilling = 0.8... Power fuel jet = no...Emulsion tube = 29
28PICT-1... 1961-1965....Venturi = 22.5 mm... Main Jet =122.5... Air correction jet=125z/130Y
Pilot jet =g55... Acc pump jet = .50...Idle air jet drilling = 150... Power fuel jet=1.0mm
Accelerator pump feed = 1.1-1.4cc/stroke...First year of Automatic choke.
30 PICT-1... 1966-1967...Venturi = 24.0 mm... Main Jet = 125... Air correction jet =125z/135z
Pilot jet = g55... Idle air jet drilling = 150... Acc pump jet = 50...Power fuel jet = __
Accelerator pump feed = 1.1-1.6cc/stroke...Larger Venturi
30 PICT-2...1968-1969...Venturi = 24.0 mm... Main Jet = 116/125... Air correction jet =125z/135z
Pilot jet = g55... Idle air jet drilling = 130/135...Acc. pump jet = 50... Power fuel jet =60
Accelerator pump feed = 1.3-1.6cc/stroke...First year for Power fuel system which draws
fuel directly from the float chamber under full load at high Speed.
30 PICT-3...1970...Venturi = 24.0 mm... Main Jet = 122.5/112... Air correction jet = 125z
Pilot jet=65... Pilot jet air bleed = 135...Acc. pump jet = 42.5... Auxiliary fuel jet = 45
Auxiliary air jet =130...Accelerator pump feed = 1.3-1.6cc/stroke...Idle speed is controlled
by bypass around the throttle plate.
34 PICT-3...1971-1974... Venturi = 26 mm... Main Jet = 127.5/130... Air correction jet = 75z /80z
Pilot jet =g50/55... Pilot jet air bleed = 147.5...Acc. pump jet = 42.5... Auxiliary fuel jet
=42.5/47.5... Auxiliary air jet = 90...Accelerator pump feed = 1.3-1.6cc/stroke...Larger
Venturi.
34 PICT-4...1974 (Calif.)...Venturi = 26 mm... Main Jet = 112.5 to 130... Air correction jet = 75z...
Pilot jet =55 to 60... Pilot jet air bleed = 147.5... Acc. pump jet = 42.5...Aux. fuel jet
=42.5... Auxiliary air jet = 90...Accelerator pump feed = 1.1-1.7cc/stroke
Float weight 1961-1967 = 5.7 grams and 1968-1974 = 8.5 grams
Note: Some books list Acc. pump jet as Auxiliary fuel jet and with slightly different sizes.
Note: The number of washers and the thickness of the washers under the needle & seat, sets the
float height and fuel level in the float bowl. The distance from the top of the carburetor body (gasket surface) to the surface of the fuel should be 19.5 */- 1.0mm or .767" +/- .040"
Washers are available in .50mm (.020"), .80mm (.031"), 1.00mm (.040") and 1.50mm (.059")
