| Buba đavo | |
Pavlepg VW entuzijasta
Broj poruka : 118 Godina : 38 Lokacija : Podgorica Datum upisa : 08.12.2009
 | Naslov: Buba đavo Čet 17 Jun - 20:39 | |
Poslednji put izmenio Pavlepg dana Pet 18 Jun - 21:29, izmenio ukupno 13 puta |
savics VW entuzijasta
Broj poruka : 123 Godina : 41 Lokacija : begrad Datum upisa : 02.12.2009
 | Naslov: Re: Buba đavo Čet 17 Jun - 21:26 | |
| Pa sa srecom  |
Broj poruka : 1446 Godina : 40 Lokacija : belgrad[e] Datum upisa : 02.06.2007
 | Naslov: Re: Buba đavo Pet 18 Jun - 10:12 | |
| imam 'jubilarnu' bubu koja je koriscena kao osnova za ovu sivu gore. samo fali sledece: • Chassis (rear axle) converted to independent rear suspension from 944 Turbo • Front and rear struts height adjustable • Brake system front: • Brake system rear: AP-Racing six-piston calipers, brake discs Ø 344 mm, thickness 32 mm, two-piece, hub / drum assemblies made of aluminum AP-Racing four-piston calipers, brake discs Ø 330 mm, thickness 28 mm, two-piece, hub / drum assemblies made of aluminum • Porsche 915 Transmission Engine: Stroke 88 mm, bore 105 mm, JE pistons, displacement 3,048 ccm, modified crankcase, camshaft 345°, "Remmele" cylinder heads, inlet valves Ø 50 mm, exhaust valves Ø 42 mm, compression ratio 11.9 : 1 Freely programmable fuel injection system with throttle plates Ø 52 mm "Remmele" central air cleaner assembly made of carbon fiber Exhaust system 4-2-1, manifold Ø 51 mm, absorbtion-type muffler Ø 76 mm, muffler Ø 180 mm Dry-sump lubrification 11 l ATEC hoses and fittingsako hoces, mogu da ti pomognem da sto brze zavrsis projekat tako sto cu ti ustupiti osnovu - za simbolican iznos?  |
axy dipl. ing. Bubarstva
Broj poruka : 330 Godina : 21 Lokacija : Zajecar,Srbija Datum upisa : 22.05.2009
 | Naslov: Re: Buba đavo Pet 18 Jun - 12:40 | |
| srecno sa novim projektom,ako ovako nesto napravis kao sto hoces ti si  |
 | Naslov: Re: Buba đavo Pet 18 Jun - 13:17 | |
| - dexit ::
- imam 'jubilarnu' bubu koja je koriscena kao osnova za ovu sivu gore.
samo fali sledece:
DA CUJEM PONUDU  I NARAVNO PUSTI SLIKE sto se tice ocekujem da bude pojava bar 80 posto slicna  |
pa3k VW entuzijasta
Broj poruka : 79 Godina : 32 Lokacija : Deč Datum upisa : 23.11.2009
 | Naslov: Re: Buba đavo Pet 18 Jun - 20:42 | |
| je l' mogu slike iz prvog posta da se malo srede da vidim sta se hoce i od cega  |
Broj poruka : 805 Godina : 34 Lokacija : Svilajnac Datum upisa : 24.10.2007
 | Naslov: Re: Buba đavo Sub 19 Jun - 0:14 | |
| srecno sa radom ima da bude kao zmaj  |
pa3k VW entuzijasta
 | Naslov: Re: Buba đavo Sub 19 Jun - 15:59 | |
| 3 plave bube  u zadnijim postovima  |
 | Naslov: Re: Buba đavo Ned 20 Jun - 16:09 | |
MikaLazarevic pridošlica
Broj poruka : 32 Godina : 35 Lokacija : Leskovac Datum upisa : 09.12.2009
 | Naslov: Re: Buba đavo Sre 15 Dec - 11:03 | |
 | Naslov: Re: Buba đavo  | |
| Buba đavo | |
